Bumnah »
https://forums.nicoclub.com/bumnah-u39849.html
Sun Feb 01, 2009 12:54 pm
Are the rotors used or new?Is there any front end vibration?My issue was warped rotors, knocking the pistons back in the caliper. I don't see that being your issue, but used rotors.... Just an option.
It's been said, but I'm not sure if you've done it, but did you test the BMC to see if it's working properly?
If I were in your shoes I'd so the following:
Fill up reservoir
Remove one hard line at a time from the reservoir and pump the pedal a few times. You'll squirt out brake fluid from the BMC, so put a towel close by to catch it. Do all three lines that so.
Re fill reservoir.
Start at LR, and start bleeding. Bleed by putting a tube on the bleed nipple, and have the tube run into a clear bottle filled with brake fluid, so you can see bubbles come out. Keep bleeding until you're positive there is no air in the lines.
Then move to RR and do the same thing.
Then move to FR and do the same thing.
Then move to FL and do the same thing.
Then test drive the car.
If you really want to be sure, take the car to a shop and have them pressure bleed the system. I purchased the Motive pressurized brake bleeder and it really helped.
BLEED BLEED BLEED.
Look very carefully at all the point that can be open, and the slightest bit of air could be coming in. I suspect the brake lines are the issue. They look fine in your pictures (but it's hard to make out anything since they're low res, and small). They make conversion lines for a reason. I actually didn't know you could use z32 brake lines on a s-chassis. I'd suspect those after the bleeding and still no improvements.
Make sure ALL NIPPLES ARE FACING UP!
