artman540 »
https://forums.nicoclub.com/artman540-u140885.html
Fri Dec 18, 2009 5:58 pm
The wheels are 18x8? with a 225 tire and a crazy high offset, hence the need for the spacer. I have a bout 4 mm of clearance between the caliper and wheel. It's really worrying me, I hope I haven't messed anything up. I literally unbolted everything and then bolted up the new. Also, with the master cylinder, does it matter which brake lines go to which ports as long as the fronts are on the fronts and the rear is on the rear? Sorry for the nubbish questions but better safe than sorry.
