300zx brake issues.
Zetec
I am currently in the process of putting Z32 brakes on my S14 but I have run into a pretty big problem. I installed the new rotors and calipers but now I cant get the rotor to rotate at all. Does anyone know what the problem might be? Any help is greatly appreciated.
navysnail
screw some lug nuts onto the studs so the rotor is on straight. did the caliper slide onto the rotor easily or did you have to force it?
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Take out your pads and try rotating the wheel. If it rotates freely, you need to compress your pistons more on both sides. It is possible that they are extended by unequal amounts on each side.
tyrannix
Car: go big or go home
is your e-brake engauged?
did you connect your e-brake properly?
(for fronts)
did you space the pistons before installing
did you bleed them properly?
CJ
jam149
Did you check which version of the calipers you have??
The 300Z had 2 versions - one takes a 30mm rotor, and one takes a 26mm rotor. With the 30mm rotor in a 26mm caliper, the pads may not be able to push back far enough to clear.
joe
http://www.negative-camber.org/jam1491992 240SX Racecar1998 240SX Track Queen
