300zx brake conversion with 4-lugs.
sausagelinks98
Car: none
I want to double check this, I can do a 300zx front brake conversion on a 4-lug s13 correct? I found some sweet rims and dont want to convert to 5-lug.Also, would it be possible to use the brembo brakes from a sentra SE-R?
94_240sx
Car: 94_240SX
Front no problem. Are you going to do rear too?
sausagelinks98
Car: none
i dont think so, I hear with the rear I will have to like mess with the handbrake and stuff so I think I'll just do the front like most and then just upgrade pads, lines and rotors in the rear.
94_240sx
Car: 94_240SX
Then you shouldn't have any problem using z32 calipers on 4-lug in the front. Sorry, don't know about the Sentra calipers.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Not a problem at all, simple re-drill of the rotors and your golden. Just don't drill it yourself, have a machine shop do it right.
-Dan
otterman
240sx2nr95 wrote:Not a problem at all, simple re-drill of the rotors and your golden. Just don't drill it yourself, have a machine shop do it right.
-Dan
Don't listen to Dan. Just get one of these:
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
as long as the center hole is the same size, you cant really screw it up. i did mine on the drill press and they work fine!
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Moved to tires/wheels/brakes/suspension.
roplusbee
Car: 2007 350Z NISMO
If I may ask, is there no way to stay 4 lug w/o redrilling 5 lug rotors to 4 lug? I don't like the idea of conversion hubs, but if it as to be done, then so be it.
I hope I did not offend the OP or forum members for using this thread. I just didn't see the point of making a new thread for a simple question.
