300zx brake conversion
brandon11130
Car: nissan 240sx hb
I saw some 300zx brakes at my uncles nissan yard and i was wondering what i would have to do to put them on my 240, has anyone done this, ive heard its getting popular, my old brakes are like shot, if i get the 300zx brakes should i also pull the master cylinder?
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Please use the search button to find the answers to your questions. The short answer is "yes" they can be fitted onto your car though performing the conversion will likely be the beginning of a spiral that will necessitate buying more and more parts. For example, if you just want to upgrade the front brakes, you will likely have to buy new wheels in order to clear the large 300zx calipers. New 16"+ wheels probably means that you will need new tires. Well, you can't just have 16" tires on the front so you'll have to get a full set for all 4 corners. Do you see the pattern here?
Hate to be a pessimist but you should be aware of the issues surrounding the swap.
brandon11130
im getting 17's so thats not an issue, i just wanted to know what i would need, do i need to buy new mouting brackets? im getting new brake lines.
Anand
Car: 95 Nissan 240SX
search... this topic has been talked about a million times..
sorry bro, but you are gonna have to do a little research on this!
