JeromeS13 wrote:If you get those, they're not going to work. You can use the stock 240sx brake lines, but its not 100% correct. If you want to do it the right way, you need to order 240sx to 300zx conversion lines. Almost every online store sells them. Check with the sponsors ------>>
Wow, I'm still new to posting on these forums but damn there's a lot of missinformed people on here.
Do not use the stock 240 brake lines. They have banjo fittings and are not compatible with z32 brakes. Yes you could fit them but it's a very un-safe thing to do since they could easily come loose.
You can most deffinately use stock 300zx lines. The only reason few people do this is because they are 2 part lines and it's difficult to find both parts without going to a NISSAN dealership. They consist of a rubber line that runs from the hard mount under the fender to a short hard line that mates to the caliper. If you have both the rubber and the short hard line these are perfectly fine. BUT, since most people feel the need to upgrade to stainless steel lines you may as well go ahead and order conversion lines. Agency Power sells a beautifull set of conversion lines at a good price. I have them and love them.
Just be sure to order the correct rotors and you are good to go. It's a simple upgrade that well worth the small effort.
