300zx Brake conversion on S13
Arashi
Car: '93 240sx LE
Hey guys, I've been lurking about the boards for a while looking at everything I can find in regards to doing a 300zx brake swap. I've been left wondering a few things.
1. Where do you guys get your calipers? Junk yard is out for me as mine are pretty much picked clean of anything useable
2. My car has ABS, say theoretically I want to carry my ABS over to the 300zx brakes. Is it possible in any way? yes/no
Thanks for any input!
Bumnah
Car: 1992 240SX, black. Bone stock.
1.) Advance Auto sells refurbished calipers. 92 300zx TT should get you the 30 mm aluminum ones. Left and right are different.
2.) ABS sensor attaches to your hub. Keep an ABS hub and you should be able to keep your abs. The calipers shouldn't affect it.
Arashi
Car: '93 240sx LE
Wow, thanks for the speedy reply Bumnah! Checking out Advance Auto now. I assume they also sell the rear calipers?
Thanks a bunch, and number 2 is unexpected good news!
Edit: Does Advanced Auto ship to Canada? So far it's looking pretty Amercan only
Edit Edit: Nope, USA only it seems. Well shoot. Looks like I need a Canadian-loving alternative lol
shimizu_17
Arashi
Car: '93 240sx LE
Nice. Thanks, I'll check them out!
Edit: I wanted to swap out all the brake calipers. I'll just need the rears if I get this kit. Don't fail me now, Nico!
Another question: Is there anything special required for swapping out the rear brakes? I read that you need to swap out the e-brake cable if you're using Z32 rear brakes, is this true?
Modified by Arashi at 8:52 AM 2/4/2009
Arashi
Car: '93 240sx LE
Bump!
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Don't you Albertans have Parts Source there? I'm pretty sure they would carry them.
Bumnah
z32 rear brakes use a drum e brake. you'll need different cables as well
not worth it if you're not tracking it.
Arashi
Car: '93 240sx LE
We do have Part Source, but I didn't even think they'd carry something like older brake calipers haha.
Bumnah: Not tracking it? The cable? Are the e-brake drum breaks a part of the rear calipers or something then?
Modified by Arashi at 12:16 PM 2/4/2009
Bumnah
do a search man. all these questions have been asked. i'm not going to walk you through it.
Arashi
Car: '93 240sx LE
Woops sorry, I'll search for the rest of my questions. thanks for the help though, man!
Arashi
Car: '93 240sx LE
Still looking for input on sources to get the parts/kits though if anyone has anymore recommended places.
I'll be checking out Part Source too to see if they have them, as I think I have enough data to get what I want.
!Zar!
Car: Countless.
Do you really need to be hand fed?
Do you want someone to install them for you?
Search Craigslist, zilvia, ziptied, here, junkyard.
It isn't that hard unless you're a vegetable.
After you buy the calipers, buy a master cylinder.
Then buy conversion lines. splparts sells them.
If you are too cheap to do a 5 lug swap, you can always redrill the rotors to 4 lug.
If you REALLY must have someone hold your hand, you can PM me. But I know for sure this has already been covered.
UGH.
kpodj61240
Car: S14 Zenki
i just did my 300 zx brake upgrade and my abs light says on. ?? could this be due to me by accidently braking off this little magnet thing on my hub could that maby be an abs sensor?
