krijohn1012 »
https://forums.nicoclub.com/krijohn1012-u37291.html
Tue May 23, 2006 6:59 am
Yeah we bled the brake....we bled the Master Cylinder.....I really think that there was no air in the line at all.......we have been using 4 bottles of brake fluid so far... but the problem still occurs.......
But the Machanics told me that right after we bled the brake, the padal was so strong....there was a lot of pressure.....however, right afrer you stepped out from the padal just a few second. Then, step on it again.....the padal went down again like there was no pressure....
I thought and tried to find the way to solve the problem all night long.......since mine is a non-ABS one which the main component are Master Cylinder, Power Brake, and Calipers.....
According to my point of view, I think that the problem might cause from the bad Master Cylinder.......since it's possible that the brand new Master Cylinder from the old stock one might have the bad rubber inside the cylinder bore........which makes the MAster Cylinder working less than what it usually does....like 50-60% . Therefore, when I first pumped the brake padal......the padal went down to the floor since there was not enough pressure to push the calipers.....but if I still pumped the padal for the second and the thrid time.....the car stopped fine......
NOw, I am wating for the New MAster Cylinder to put in....Hopefully, changing the MAster Cylinder will bring my s14 back to live again today.....
