300zx brake calipers on a S14
Riley2.4L
Car: 1995 240sx SE (S14)
Hey I've been thinking about installing the OEM brake calipers from a 300zx on my S14. They look alot better and are bigger than those dinky things on the 240. If I were to do this would I also have to run new brake lines? My car is a '95 so should I get the calipers from the same year or does it not matter. I know alot of you right now have just realized I'm a beginner at this but if you could help me out that would be great.
Riley
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Any Z32 300zx caliper and rotor will work. Just be carefull you choose all of one type, there are the 28mm wide rotor type, and 30mm wide rotor type. If your S14 is SE trim, the 30mm wide calipers will fit under the stock SR rims and the rotors wont need to be drilled either which is a conciderable bonus.
Welcome to nico! Dont hesitate to ask questions if you cant find what your looking for in previous posts
Riley2.4L
thanks for the help J-Spec. but I still don't know whether or not I have to run new brake lines for the bigger calipers
BSeay1
Car: 1995 240SX SE
yes you're going to need conversion lines for the 300ZX calipers because if im correct the caliper from the Z has a banjo fitting to where the 240SX doesnt have it...
but make sure that you get matchin rotors because the 30mm rotor and the 26mm( not 28mm) will not interchange between calipers...
Onizuka
My bad, forgot about the brake lines, its what bseay1 said.
By the way, welcome to you too!
240SicknessX
Car: 96 240 SE
yea the fronts are pretty easy....... rears on the other hand are a little more involved.
*the complete brake swap, explained*http://importnut.net/300zxbrakeswap.htm
it would be easier to get everything off the same car, well at least get all the calipers and rotors from the same car, those are the things that can get mismatched and could cause complecations.
ironically im installing the front z32 brakes on my friends s13 today.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
the rear calipers are as easy as the fronts, its the dang e-brake assembly and splicing the ebrake lines that is a royal pain. oh not to mention having one of your speed bleeder leak break fluid all over one of your new rims but would i do it again?
Nismo_Freak
Car: 89 Nissan 240SX
http://www.splparts.com for cheap brake lines btw.
Toddles82
Car: Computers, Water Skiing, Cars
Nismo_Freak wrote:http://www.splparts.com for cheap brake lines btw.
cheap brakes line that rawk!
everyplace else is going to charge you 80 for just the fronts. 80 for all for corners at SPL!
Nismo_Freak
Toddles82 wrote:cheap brakes line that rawk!
Hehe... SPL does indeed rock.
