300zx BOV installation help with vacuum lines
keeganalennie
Car: 92 300zx tt
hi there, i am almost done installing my BOV's and i am just not sure where to put the vacuum lines to. there are 2 on each BOV (one on the end and one on the side. please help me with where they go
BOV's are HKS super's.
Modified by keeganalennie at 10:45 PM 6/25/2009
ztommyx
hope this helps.
if you have a boost control, it is "T'd" to the vac line.
keeganalennie
Car: 92 300zx tt
i don't have boost control and i am still looking for some help.
i need to know where the two vacuum lines from the BOV go.
SilverTwin(OH)
Car: '91 300ZX Twin Turbo
You use the stock recirc valve vacuum feeds. You can disconnect them from under the intercooler pipes where your new bov's attach. On the passenger side the hose runs from the balance tube to a fitting under the outer intercooler pipe. On the drivers side, it runs from a port on the side of the plenum down to the intercooler pipe.
You will also need to cap off where the "U" hoses from the stock recircs attach.
keeganalennie
Car: 92 300zx tt
ok that takes care of one of the two on each BOV. where does the other line come from?
keeganalennie
Car: 92 300zx tt
please help. my car is not drivable until i find out where the other nipple connects to. i have searched this forum and the internet for hours now.
thanks.
sonozx
Car: 1995 z32/NA
mybe this help !!!
zerothread?id=413669
hi guys
keeganalennie
Car: 92 300zx tt
ABSOLUTELY PERFECT. thank you very much. great thing to wake up to. cant thank you enough sonozx!!!
keeganalennie
Car: 92 300zx tt
hot them in yesterday. they look great. they sound good too. the only time i have noticed any decrease in smoothness is when i would be driving slow and put my foot all the way into it. it sputters a little. if i ease into the first bit then it is fine.
idles same as before.
i am happy with them, also did a k&n cone at the same time because there was no way that i was putting the OEM air box back it (so hard to remove).
i deleted the recirc valves and every thing related to the OEM set up in a way that it can be reverted in in less than an hour.
thanks for the help.
mikep1745
Car: 1992 240sx hatch
looks good
PAz32
Car: 1990 300ZX NA-TT
keeganalennie wrote:
Sat Jun 27, 2009 6:05 am
sorry to dig this back up years later but i have the exact same issue and cant find anything to help me out on where the vac lines go
NolimitZ32
you can connect them to any stable vacuum source on the manifold or to the nipples on the back of the accordion pipes.
