300zx BMC CHANGE PROBLEM...PLEASE HELP
rewjr69
Car: 1990 300zx 2+2
1990 300zx NA
My bmc is leaking through the tiny middle hole between the brake lines. I got a new nabco mc and am ready to bleed brakes and replace the mc.
However, the 2 nuts holding the brake lines in the master cylinder seem to be fused shut!!!! I've used a 10mm open ended wrench and a vise grip to no avail. All that did was smooth out the hex shape of the nuts...
Can I cut my lines and attach some sort of extender?? Where and what size nuts can I buy to replace the ones I've damaged??
Please help. Brake pedal is spongy, rolling to a stop right now
robomatic12
Car: 1990 300ZX TT
rewjr69 wrote:1990 300zx NA
You needed to use a tool called a flare nut wrench, its closed 3/4 of the way around so it doesn't round the nuts off. Unfortunately if you have rounded them off you either need to cut and reflare the line with a new nut, or replace the brake line. Also make sure you bench bleed the new mc before putting it in.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
sounds like it's a bit late for the flare nut wrench
soak them in pb blaster or similar and get a pair fo these
http://www.toolking.com/irwin-7lw-7-inch-locking-wrench
they look wierd but work great on stripped out brake fittings
also a small pipe wrench works well
