k6kicker »
https://forums.nicoclub.com/k6kicker-u10135.html
Wed Dec 22, 2004 6:04 pm
depends on if it is an NA or a TT...NA will be the same as the one you currently run (ratio wise) but the TT will be a taller gear (IE will run a lower RPM at any given speed compared to what you are at now, also meaning a cut in acleration, but a higher theoretical top speed)
