300zx alternator bolt
skyline084
Can someone please identify the bolt that holds the bracket to the block near the oil pan for the alternator tensioner.
It's the one closest to the crank pulley, right above the oil pan. It gets threaded into the block.
I cannot find the right bolt or schematics on it for the life of me.
If someone could tell me the thread size I would greatly appreciate it.
agent4573
M8x1.25 80mm to the bottom of the hex head, 85mm overall including the hex head. This isn't the stock bolt I'm using, but it goes in and tightens downs and works fine for me. The original might be a bit longer or have a different style head on it.
skyline084
agent4573 wrote:M8x1.25 80mm to the bottom of the hex head, 85mm overall including the hex head. This isn't the stock bolt I'm using, but it goes in and tightens downs and works fine for me. The original might be a bit longer or have a different style head on it.
Found one.. Thank you
