300zx alignment
gohan247
have a 94 nissan 300z manual n/a two sweater. Just brought it and hand to change the driver side lower ball joint and lower arm. Had alignment done but it still pulls a lot to the left. Sometimes if I turn slowly to the left the wheel will try to stay turn while the right side responds to the steering. Any advice welcome I think the left side may have run over a curb or something
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
What the alignment sheet say after it was done was everything able to be brought back to spec?
ThisIsSparTTa
Car: 91 300ZX TT 2+0
gohan247 wrote:Sometimes if I turn slowly to the left the wheel will try to stay turn while the right side responds to the steering.
This sounds exactly like the problem I had with my Power Steering Rack bushings. They were so gone, they fell to pieces as I loosened the PS rack. Sloppy sloppy steering, and when I turned left, the wheel wouldn't recenter properly, and when I turned right, it would. http://conceptzperformance.com/Cart/des ... .164.62.64
Z-owned
Car: 93 N/A Z32
90 VW Corrado
01 mr2 spyder
With the front end off the ground you can grab a wheel and check for steering rack play. Bad bushings would definitely cause issues and if the car aligned fine is likely the issue. Otherwise a bent tension rod lower control arm etc would cause issues but should be visible and show on the alignment sheet.
gohan247
Thanks to everyone will check on this this weekend
gohan247
I am also looking for a set of tires for 300zx 16" eom low cost or donation used will be great. Want to work on alignment issues.
ThisIsSparTTa
Nexen N3000 and Fuzion ZR1s are the only ones making tires for the stock rear size. They're relatively cheap, ~$100/tire.
gohan247
Hello everyone have to replace my ignition switch for my 94 300z have to change the door lock or rekeying it . anyone have the easies way to do this?
