300zx air intake hoses
Nissan 350z / Nissan 370z general community discussion forum
elorenzof
Car: 1986 Nissan 300ZX non turbo
Please see pic,
I replaced the valve cover gaskets on this 1985 300zx non turbo, and the two hoses in the pic circled in red have dry rotted and had to be cut off.
I tried to use regular hoses but they wont fit due to the bends and curves. Can someone please help with the part number
and identification of these two hoses? They come off the air intake, one goes into the valve cover, but i dont know what it is called that the other one goes into.
Lorenzo
2003PATHFINDER2022
Car: 2003 Nissan Pathfinder 3.5
2006 Nissan 350Z
I had similar situation on my 79 Toyota Land Cruiser, I went to a good parts store, found an assortment of small matching diameter radiator hoses with a lot of bends and angles picked one and found the shape and bends I needed, cut out the pieces I need and installed, easy peasy!!
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You can also put a coil spring over or inside any hose to keep it from collapsing on itself.
Return to “350z / 370z Discussion”
