How ever im here because i need help with my Z. Its a 1996 therefor OBDII compatible and getting a "check engine" light on. Plugged in the Code Reader and popped up code "P0505" relating to the AAC or Idle Air Control Valve...
I was wondering if any parts from the Infiniti J30 can fit the 300zx? I heard they share same engine and transmission?
I found an AAC from the infiniti and seems the same except from the "T" shape tubes where the air goes into the actual valve. I heard there are more than one versions of AAC that Nissan produced and that these two will perform the same. Can anybody confirm this?
The Z32 AAC
**Notice the back part of it how it differs with this one that i found and want to get..
Its a bit blurry but you get the idea...
And this is the Infiniti j30 Valve, looks the same but T tube differs.....
Will they both work the same???
Also sorry for the bothersome but was wondering if anyone has been successful with relocating there knock sensor to the top of the plenum? My Z threw a code a week ago or so, erased and hasn't came back yet but it sometimes does after 100-200 Miles...
Any help will be highly appreciated.
