redtop91 »
https://forums.nicoclub.com/redtop91-u46681.html
Sat May 19, 2007 6:52 pm
^ He has the 300zx calipers now. MASSIVE NO NO USING THE STOCK LINES ON 300ZX BRAKES!!!!!!!! If you use the stock banjo fitting, even with a shorter bolt, it is not the right fitting for the 300zx caliper. The Z brakes don't have a tab to hold the banjo fitting in place and the fitting will spin and loosen the bolt which is probably what you are experiencing. VERY DANGEROUS! I don't know if you have a Q45 or a 240 since your profile says Q but you posted this in the 240 forum, but the lines on the Q and 240 are similar enough so the same rules apply.
