Toddles82 »
https://forums.nicoclub.com/toddles82-u7840.html
Mon Jun 21, 2004 1:09 pm
It's in and working, and no visible signs of leaking.
I will post pictures in a little later.
You are right, the pedal is friggin' stiff as hell. Current Setup includes the follow with no power mods: (listed because it influences lockup)300zx LSDAGX/PK's30 mm 300zx calipersstock 300zx rotorsAlbany pads (Autozone cheapys)Kumho MX's 205/55/16a few bushings here and there
First test drive, I was dissapointed. Wouldn't lock up for the life of me. Standing on the pedal at 60 mph wouldn't do ****. Did several other hard braking situations and wouldn't lock up at all, and I also thought for my current setup the stopping distance should have been better. Came back, and let my dad drive. Holy hell, second time out they were much better. Locked the tires up very quickly and skidded true (straight). Impressed.
This was also the first time my brake system had been flushed and bleed that thoroughly.
I have admittedly not driven the car since it started stopping better.The only con is the brake pedal is very firm and doesn't seem to have much depth to it. All the breaking effort seems to be in the top 1/2 - 1" of the pedal. I also admit that this is the point where you can't use cheap pads. The cheap pads don't seem have enough bite to use all of the 300zx components capabilities. They feel like the harder you press the more the rotor slides right past the pad. I would also say whenever someone does the MC upgrade to also use a decent set of pads.
I'll do a better right a bit later.
Thank you all for your help and suggestions, albeit some I already knew. At least people posted tho. In my other forum (which I will probably no longer visit) not 1 person has responded)
