before i rotated it---------->
After i rotated the cam didnt line up with the whit line?i rotated the engine multiple times..
everything still lines up but without the timming belts white lines?
SHOULD THE CRANK BE TURNED ONE MORE TOOTH OR IS IT OKAY THIS PIC WAS TAKEN AT THE SAME TIME THE TWO PICS ONTOP OF THIS ONE WERE...WHEN I TURNED THE ENGINE I DIDNT FEEL ANYTHING HITTING AND COULD HEAR THE COMPRESSION IN EACH CYLINDER because the spark plugs are out thank you
