I know we discussed HFC's on your other thread, but you should try and go to the G35/350z classifieds and pick up a set of used OE cats... I know you can get a pair for less than $150svard75 wrote: I actually have to replace my cats and thought of going with high flow cats but at the same time didn't want a constant drone on the highway. So definitely not aftermarket exhaust friendly either.
How much would that cost for an M35x since there are two differentials and can you buy them ready-fit or do you have to have custom gears made somehow?svard75 wrote:Mine performs the same way. It's not fuel efficient but it's better in a sense it doesn't always need to downshift to get it over a hill.
But reliability, looks and function should trump this minor problem. If you really can't live with this then think about some new front/rear axle gears. 2.95s?
It would be expensive. Probably so much that the cost of gas difference between the MPGs over the lifetime of you owning the car would barely brake even to doing the mod.Brian35XR wrote:How much would that cost for an M35x since there are two differentials and can you buy them ready-fit or do you have to have custom gears made somehow?
Hey Thanks man. I checked it out and found one guy but missed the boat. They were OEM cats too! I'll keep my eyes peeled there.CPJ LB wrote:I know we discussed HFC's on your other thread, but you should try and go to the G35/350z classifieds and pick up a set of used OE cats... I know you can get a pair for less than $150svard75 wrote: I actually have to replace my cats and thought of going with high flow cats but at the same time didn't want a constant drone on the highway. So definitely not aftermarket exhaust friendly either.![]()
either in this forum or G35 Driver.... they also have Canadian classified sections
http://g35driver.com/forums/canadian-classifieds-66/
