OP, get some new style injectors and fuel rails and call it a day. Should be around $1300 parts and labor.
txQ45 wrote:Most Z's with the OLD STYLE injectors are going out..
If you're going to replace them take a look at the Winfactory top feed with bosch injectors.
These are made for alcohol and will take the E85,
E85 is like 100+ octane so you can safety run a higher boost = more HP
You need more than just injectors to run E85 man. The stuff will eat your whole fuel system unless you replace most of it.
