Huh... the stock MAF will do 270whp or so before it hits 5 volts.Dori Dori wrote:He'll NEED to do a MAF since the stock maf won't flow more than 230ish.
Larger injectors will also be needed, S15 injectors should suffice.
An ecu tune will get you closer to 300whp with less boost and a better timing curve than an SAFC.
this is wrong . u do not need a stand alone or cams or low compression pistons. t28, maf, injectors and a piggyback or rom tune THATS IThazw8st wrote:He'll have to tear down the block and install some low c/r pistons. he'll have to upgrade to at least a T28, cams 272 intake, 269 exhaust, megaquirt ECU or a Standalone ECU.
No. A stock block SR20 is easily capable of 300whp with a larger turbo and supporting fuel mods. Low C/R pistons are not necessary if all you're running is a t28.hazw8st wrote:He'll have to tear down the block and install some low c/r pistons. he'll have to upgrade to at least a T28, cams 272 intake, 269 exhaust, megaquirt ECU or a Standalone ECU.
but we're telling him its not possible. besides the guy that we were correcting also said to change turbo. bottom line change the t25S13240 wrote:Wildacexxx & AmoebAssassin: You guys need to pay attention a little bit better to what the original poster was asking. On stock t25, not t28. Anyone can do 300 whp with t28, but original poster is asking how to get 300 hp without changing turbo.
I was correcting the man above me. My post was not about t25 vs. t28.S13240 wrote:Wildacexxx & AmoebAssassin: You guys need to pay attention a little bit better to what the original poster was asking. On stock t25, not t28. Anyone can do 300 whp with t28, but original poster is asking how to get 300 hp without changing turbo.
Never seen it happen...Nismo_Freak wrote:Huh... the stock MAF will do 270whp or so before it hits 5 volts.
me either, or at least safelyDori Dori wrote:Never seen it happen...
I dyno'd almost 240 at 14psi on a stock turbo/maf/injecs. I said 230ish...meaning give or take. Because of climate changes, altitudes, and dyno variances; I'm not going to be specific about it. Take "ish" how you will. Regardless, you're saying 270whp is possible on a stock MAF. Show us.Nismo_Freak wrote:There must be at least 500 S13 SR's running stock MAF with over 230whp. Hell I've known people to run that setup for years without a problem.
thats a good idea! Im also looking at kits..TURBOHHH wrote:well you are right about 250 being close to 300 very very true. but i have desided that the t28 is out. im just going to by a whole kit. besides im goin to spend the same money on a t28 and getting it tuned right and only makeing a little over 300 when i can buy a whole kit and make 400. makes sense to get a kit huh? well i really need to go to the dyno and see what im putting down know.
This is from a guy with a larger T28:Dori Dori wrote:I dyno'd almost 240 at 14psi on a stock turbo/maf/injecs. I said 230ish...meaning give or take. Because of climate changes, altitudes, and dyno variances; I'm not going to be specific about it. Take "ish" how you will. Regardless, you're saying 270whp is possible on a stock MAF. Show us.
