itsa300zx wrote:Here are the dimension I used for the aluminum plates, two of each:
3.5" long x 1" wide x 0.305" thick; drill hole dia of 1/2" at 2.25" apart centred
4.125" long x 1" wide x 0.305" thick; drill hole dia of 7/16" at 3.125" apart centred
Bolts, four of each grade 10.9:
Note: grade 8 imperial = 10.9 metric; grade 5 imperial = 8.8 metric
M10x1.5 40mm length
M12x1.75 90mm length
Hope that helps
Peter
You're awesome!! Thanks man
Where did you get the 0.305" thick aluminum from? I stopped by Lowes today but all they had was 0.0625", 0.125", 0.1875", 0.25", and .375". I was thinking about putting a 0.25" + a 0.0625 so its 0.3125 thick, but I'd rather use just 1 piece.
