There are 500+whp B18 Hondas so I don't think a stroker kit is necessary (even if it were, the Tomei 2.0 kits are like $4,000). Recipe for 300whp--marauder s12 wrote:What's up yall, I'm new to the forum and turbo/fuel injection world(been working with old Chevy Rat Rods and Harley Davidsons most of my life).
I'm just about to start a rebuild on my CA18det, and I was wondering if you guys could give me some pointers, advice, suggestions, or recommendations on parts to achieve 300-350 RWHP. I don't want to stroke it(i.e. stroker kit, LOL) unless you guys think that's the only way, but other than that I'm open to ideas.
Thanks in advance for your time and info.
No way are 440s enough. 450cc's max out at 280hp @ 95% duty cycle and 15psi with a base pressure of 43.5psisilvia_ca18det wrote:300wps is gainable on a s15 BB turbo at 14 psi
440cc injectors, rb25 maf, hks frontmount, ecu tune and CAMS
with those minor mods 300wps was put down going beyond there i recomend a solid buildup of the bottome end!
Secondly, 300whp is pushing it with the S15 T28. You would be maxing that turbo out big-time.
That's basically what I was getting at in my post before I realized I needed to edit it. Except that 440s would be hella maxed out. You don't want to bump the fuel pressure that much because that will have a serious effect on your idle and off-boost driving. To me, bumping fuel pressure is a bandaid. Ideally you don't want to run more than 85% duty cycle on your injectors. Personally, I wouldn't run anything less than 550s if I were trying to get the most out of a T28.slownslurious wrote:I was pretty sure the 440's would hit 300 that should have them pretty closed to maxed out... it depends on your fuel pressure too, if you crank it up a tad you can get more out of them. 300 whp on the S15 T28 is probably past its optimal efficiency range so you better have a big IC to cool down the air flowing off that heatpump...
This is EXACTLY the reason that I'm running 550's. I Know that I could probabally get 300hp out of them, but I'd be close to the limit. Why risk it? The 550's are fine at idle, and have plenty of head room at 300hp.c-rad wrote:
