You are trippin, negative offsets on wide wheels is goooood on a 240.KC240SR wrote:anwhere from +25 to +35 I believe are relativly often used. but then again...some of the sportmax wheels and most meshies are anywhere from 0 offset to like +15. But generally negative offset is a no no for a 240.
Are you smoking? Negative offset in general for a 240 is not bad. Sure an 18X12 -30 is probably going to have issues on a stock bodied 240, but a 15X8 -30 is ok with adjusted camber, fender roll and pull/small flares.KC240SR wrote:anwhere from +25 to +35 I believe are relativly often used. but then again...some of the sportmax wheels and most meshies are anywhere from 0 offset to like +15. But generally negative offset is a no no for a 240.
Negative offset is not bad, but not good. Not good for wheel bearings, not good for fitment on stock fenders, not good for the steering axis inclination, not good for wheel return.SlipnSliden 240 wrote:
But for a 15x8 -30 I would just pull the fenders should be close.
FYI I run a 18x9.5 -22 under pulled front fenders. Tire size, camber, and a bat is all you need.
Tsukiko wrote:there is a way of adjusting camber in the rear without new parts, but i personally would never do it.
Tsukiko wrote:
Im not going to bother finding the thread
Bought house, had kid, sold car, some teenager immediately wrecked it.Clawhammer wrote:Yes, and omg dude where did you go...you don't know me I joined around the time you disappeared but lurked for years before that...
Im not to woried about wheel bearings. Just because I have a low offset dosent mean they will fail tomorrow,Maybe 15K mi early I can deal with that. I run 12* caster on my front wheels, my wheels return just fine. Most negative aspects can be corrected with a proper alignment.devil_child wrote:Negative offset is not bad, but not good. Not good for wheel bearings, not good for fitment on stock fenders, not good for the steering axis inclination, not good for wheel return.
The most ive seen pulled is like 30mm on the stock fenders, even then, that requires professional work to look right and is hard to achieve.
