weighit »
https://forums.nicoclub.com/weighit-u119710.html
Wed Dec 03, 2008 7:09 pm
They are wanting to drain and flush the transmission, replace the radiator cap, replace the fan belts or belt?, flush the engine oil not just a regular oil change, and replace the filter, replace the inside cabin Hepa filter, replace the engine air filter, do a injection cleaning, rotate tires and balance and replace the wiper blades. The question becomes is the trans oil change really needed at 30,000 miles. I read the factory installed fluid is good for 100,000 miles. Today i called 4 other dealers, got 4 different figures. One dealer said not to change the fluid, a $200 repair, as it is not needed??? He suggested only changing trans oil at 60,000 miles if I wanted to. They do not remove the trans pan and replace the filter, something he said the factory does not recommend. I'm confused?????
