3 trannys in 1year
bladeQ45
Car: 1990 infiniti Q45
3 trannys in 1year, what is the problem? well i know! it was the only used thing i put in the Q, and it failed. butt!! all 3 in 1 year???. no i have not did the timeguides need to get it done!!!!!!!!! just learned about it and out of budget DAMN!! i need to be a member a year ago!!! i missed the most inportant than. the timeguides and low low low budget well suck and L.E.D multi color is under it. and inside thank BladeQ45
bladeQ45
That silver door! Did you survive a shooting?
bobotech
Dude, wahts with the door?
It looks like you live in the hood and got shot up by some bros.
bladeQ45
lol ha not the hood
zerothread?id=149667
ejXa q45
Car: 1992 Q45 infiniti sliver
i know what happen to the door....
a hammer ....... look under the door in the pic. now that not the way i would take the door off ...i think you would use a socket
ejXa q45
one more thing did you paint that silver Q red... tell me that is a different car .... silver is one of the hardiest color to paint
JebsNYCQ45
Car: 1994 q45
WHATS THE NAME OF THAT COLOR YOU PAINTED THAT THING... AND DID YOU TAKE EVERYTHING APPART BEFORE YOU PAINTED IT.....LIGHTS, TAIL DOOR , TRIM ,,,ETC ETC ETC YOU KNOW WHAT I MEAN
nchopp
ejXa q45 wrote:one more thing did you paint that silver Q red... tell me that is a different car .... silver is one of the hardiest color to paint
It was originally silver, he repainted.
Could you maybe size down the sig pic a bit?
bladeQ45
bladeQ45
Q_SHIP
Car: 1999 Q45T with a billion miles.
bladeQ45 wrote:3 trannys in 1year, what is the problem? well i know! it was the only used thing i put in the Q, and it failed. butt!! all 3 in 1 year???. no i have not did the timeguides need to get it done!!!!!!!!! just learned about it and out of budget DAMN!! i need to be a member a year ago!!! i missed the most inportant than. the timeguides and low low low budget well suck and L.E.D multi color is under it. and inside thank BladeQ45
I just don't understand why you have posted the same paragraph 3 maybe 4 times now. Kind of confusing.
bladeQ45
well i dont have any more pic of the car just got it back. we painted it in 12/2/2005 to 12/12/05 so see why i only have a few pics of car and as soon as i got it back the transmission goes OUT!! need to get a transmission.
so if you know anyone with a spare LOL transmission let me know
bladeQ45
ejXa q45
is this better
ejXa q45
i know im ***hole
happy holidays
Q45tech
After 3 one should learn that the very worst used parts buy is a USED then sitting automatic transmission. Fresh factory remans are always the way to go unless you don't mind paying swap labor [$600] time and time again hoping to find a functioning one
RobertsnewQ
No crap.
And if I was the one doing the install I wouldn't warranty it unless he at least had the cooler lines flushed and a filter installed, if not an external cooler.
Where do you think all the crap from the two previously dead transmissions ended up?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
RobertsnewQ wrote:No crap.
Exactly why dealer SOP demanded replacement of the radiator and its heat exchanger, later changed to a flush procedure in a TSB, on the pre 1994.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
and they installed the filter so the cooler wouldnt clog.
DrewQ45
Car: 1990 Infiniti Q45
Q45tech wrote:After 3 one should learn that the very worst used parts buy is a USED then sitting automatic transmission. Fresh factory remans are always the way to go unless you don't mind paying swap labor [$600] time and time again hoping to find a functioning one
Not bad advice....
I have a little experience with this since I went through two transmission replacements in the past few months.
At 190K my orignal transmission failed. I visited a JDM importer and picked up a used transmission.... You might remember engline.com Tech? After install we found out the transmission was pure junk... I had to muscle-up to shift from P to D and it slammed as if someone had rear-ended me.
One mistake I made was not having them drop the pan.... my mechanic informed me that when he pulled it, he saw enough deposit on the magnet to form a small sculpture. I had to eat the labor on that and get a 2nd unit elsewhere. BTW I was smart enough to purchase it using AMEX then dispute the claim at the first sign of resistance to a refund (the seller bellied up fast and gave me my refund once they contacted him).
I have a good one now from another JDM importer, but this time I took my time checking out a few trannys... having them drop the pans to examine magnet filings, examining the condition of the dipstick etc. The transmission I got seemed hardly used if basing observations on aesthetics. The dipstick still had the tiny shiny sticker on the handle with Japanese writing... the transmission mount was also attached and in great condition, an unusual case and another clue on it's usage. The entire unit was clean but not in a washed sense....etc. Not much to go on, but a lot better than nothing.
The transmission shifts crisply and cleanly and the oil pan has a drain plug so I'm happy...but I lost $500 (labor) in the process.
The bottom line...you take a big chance. For me, the cost was still way below having a dealer reman installed (saved on shipping too)... At 3 units, I'd just give up and go the guaranteed route.
..Drew....
Modified by DrewQ45 at 2:33 PM 12/22/2005
RobertsnewQ
If mine goes out I'll probably get a japanese pullout, but get it directly from the importer and do as you suggest - if they're all the same price it pays to get the best one there.
DrewQ45
RobertsnewQ wrote:If mine goes out I'll probably get a japanese pullout, but get it directly from the importer and do as you suggest - if they're all the same price it pays to get the best one there.
Coming from the man who wrote the book, I'm honored that you'd take my advice. ....always a good thing to learn from someone else's mistakes.
If you ever need one and have trouble finding one nearby, I'd take a trip to the 2nd seller I dealt with and pick one out for you. They claim to have never sold a bad one (coughm, cough).... It's the least I could do for the man who will reprogram my future ECU..which I'll be shipping to you sometime next week.
...Drew....
RobertsnewQ
Well, I know a lot about MANUAL transmissions. Automatics I'm no pro. And I don't have a shop so I couldn't do anything about it if I wanted to.
