2kdet »
https://forums.nicoclub.com/2kdet-u46474.html
Tue Sep 05, 2006 6:05 pm
Hello,I have a 1993 NX2000 WITH A DET SWAP.The car is running like crap.I have changed the following items
Dist cap and rotorwiresO2Spark plugsSwaped out injectorsCompression Test 120psi across the board.What should the compression be?
After all that I have done #3 cylinder's plug is still sooty/dry fouled.While the other plugs are perfectly normal.I also interchanged injectors,but still the same thing.I am really stomp and need advise,any help will be appriciated.
Modified by 2kdet at 9:18 PM 9/5/2006
