Rosco »
https://forums.nicoclub.com/rosco-u15015.html
Mon Jul 25, 2005 10:23 am
Okay, I have viscous 180sx LSD (w/NISMO 4.4:1 gearing) with the 5 bolt axles...What I need is the boot on the axle (diff side). Mine is cut...I tried explaining what I had to local nissan dealer but he had no idea what I was talking about...So basically I need a boot re-seal (on diff side) kit for the 5 bolt axle...I ordered the one for the open diff hoping it would be just right, but it's too small....Maybe someone knows where to get this or have a part number for it? My other LSD question is: On the rear faceplate of the diff there are 4 studs, well one stud needs to be removed and replaced and I have tried using vice grips but it was to no avail....Any tips on how to remove it? What stud can I use to replace it?
SR question:I removed my oil pan so I can place my trust one on the engine...I need to know what are the torque specs are for the bolts on the flat plate inside the oil pan( I'm not sure what the exact name is but it surrounds the oil pickup.)?
