sxseguy »
https://forums.nicoclub.com/sxseguy-u5378.html
Tue Jun 08, 2004 3:23 am
Bah! Drifting an automatic is not much different from drifting a manual transmission car. The key is gear selection. You HAVE TO manually shift it to keep it in the part of the powerband you want. Other than that, you can still use e-brake, lift-off, power-over, shift-lock, feint and whatever other skills are in your arsenal to get the thing sideways.
In addition an automatic has one other trick up its sleeve. It's a variation of power-over and it's done by holding a lower gear close to redline and UPSHIFTING as you begin to turn in. When the transmission shifts, there will be a split-second instance where the torque converter does torque multiplication, yielding an extra 40 lb-ft of torque right near the engine's torque peak to kick the rear end out. Can't do that with a manual transmission!
