3 problems.....'93 J30 119k
ceenotes1
Car: chess, fixing things that dont work
1st - after driving on the highway for about 45min, after stopping then stepping on the gas the car boggs out and stutters like it doesnt want to go. I had to stomp on the gas to kick it into overdrive...???? what is that?
2nd - the front passenger window comes out of the regulator clips when rolled down. Do I need a new regulator or can i just change the clips?
3rd - the rear drivers side window doesnt work at all. I cant here the motor when either main or rear switch is depressed.
thanx...
j30t
the rear window most likely needs a new motor. go to car-part.com and search for J30 window motors...theyre arent too expensive.
WAMP
Is your avatar gorilla from slam dunk?
Eswift
Car: should be obvious enough
when you stomp down, you are pressing the kickdown switch and the transmission automatically downshifts. this function also depends on current speed.
cant know for certain, but your problem sounds to be fuel system or intake related.
fuel filter, fuel pressure regulator, fuel pump, vacuum leak, PCV, stuck EGR, maybe even plugs.
