3 inch straight pipes Z32 TT?
z32_Chase
Car: 91 Z32 TT 2+0 + 91 3000gt VR4 forged motor, Apexi AFC NEO
I was thinking about putting dual 3in Straight pipes to dual 3in tips with a resonator on each love the sound of the turbo spool :yesnod . So what im wondering will doing this mod decrease Hp due to less back pressure etc
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
Back pressure is a bad thing, no matter which engine you have. It's an old muscle car era misnomer. What these guys were actually referring to was the exhaust scavenging they got by running the correct sized exhaust (header on back). On a non-turbocharged engine, having the correct sized exhaust based off of your engine specs is crucial. This is why a large exhaust on a smaller N/A engine will lose power. HOWEVER, on a turbo car things change up a bit. After the turbocharger, it is best to have a rather large exhaust with mandrel bends (turbine exhaust spirals down the walls of the exhaust rather than "pulses" like normal exhaust to put it in simple terms).
So in short, running a dual 3" exhaust will not lose horsepower, in reality, it will be an improvement.
z32_Chase
oh ok ive been told you need back pressure but i guess he doesnt know what he is talking about so.. thanks!
Slizz
Car: 92 nissan 300zx
:werd:
z32_Chase wrote:oh ok ive been told you need back pressure but i guess he doesnt know what he is talking about so.. thanks!
NolimitZ32
once you have an open exhaust on a turbo vehicle, it is important to maintain velocity until the gasses exit the pipe, this means that in essence you need an exhaust that will taper smaller as it gets closer to the outlet to ensure that the available volume decreases with the contraction of the gasses as they cool, in reality I don't think there is much of a difference if you run full 3" or 3" to 2.5" but then I've never been involved any dyno sessions to prove this either way.
