3 Inch Mandrel Bent Exhaust Piping, where can i buy it ?
The All Mighty KA-T
Car: 1995 Eclipse GS-T
I'm looking for some Mandrel Bent Exhaust piping b/c i'm wanting to make my own custom 3inch turboback exhaust...........anyone know where i can buy some.
P.S. I looked on e-bay and i seen some 3inch Mandrel Bent Aluminum intercooler piping and i just wanted to know if that would work?...........thanks guys.
Titan
The All Mighty KA-T wrote:I'm looking for some Mandrel Bent Exhaust piping b/c i'm wanting to make my own custom 3inch turboback exhaust...........anyone know where i can buy some.
I get mine through a shop that sells through Keystone.
From there you can order either Headman Headers or Hooker Headers. Both sell mandrel 3" bends.
You can get either 18 gauge (0.049" Wall) mild tube, or 16 gauge (0.063" Wall) mild tube.
I would recommend the 16 gauge.
Mine cost me $48 CDN ($41 USD) each for a 180 degree bend. This way you can cut to get two 90 bends. These are J-bends that come with a 6" leg and a 15" leg if I remember correctly.
When I built my downpipe and cat back, I used atleast three 180 degree bends in total.
So you are looking at atleast $120 USD in bends, plus about 4' of straight 16 gauge mild tube. I happen to have my own TIG welder, so I had no costs there. However, if you do not have your own welder, you will need to add this cost.
Furthermore, you certainly DO NOT want to use aluminum for an exhaust, especially the downpipe.
The melting point of aluminum is 1220 F
Compared to mild steel at 2759 F
You'll be reaching in the 1000-1100 atleast with a turbo setup. Not necessarily on a consistent basis, but enough to soften the metal dramatically.
Not to mention you will have to TIG weld the aluminum. Meaning if you do not have your own TIG welder, you will be paying premium dollars to a fab shop.
Better to just get a piping kit.
I can check our price, I don't thnik it's too bad.
H.D.HUMPERDINK
Car: '92 240sx
summitracing.com or jegs.com
teddy
Car: Saab Turbo and MR2
