DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sat Sep 24, 2005 8:06 am
RIley2.4L why do you keep going off that someone needs to find you a dyno of 2.5 vs 3? clearly you've never seen this comparason either so how can you sit there and argue something that you yourself have never seen, and then use that as your point why he must be wrong.
Not only have you made the worst argument ever, being a hypocrite in the process, but you must be a 17 year old JDM Fan boy.....
and whatever about that dyno earlier about losing two horse from adding a test pipe. Thats the least credible comparason ever for a few reasons.
A)Dyno runs are hardly ever 100% repeatable and consistent. If you need a specific example just go back to that Freshalloy thread and check out all the inconsistencies in the dyno runs. With a baffle all the sudden it makes 138 then 133 and then 130? why is there an eight horse difference? clearly this guy with the test pipe didnt make nearly enough runs to make a reliable average.
B) I don't know how well that dyno program compensates for humidity, temp, and other outside factors, but those runs were made an entire day apart and one was made in the morning and the other was made at night.... lets make a run in the winter and then another in the summer and compare then with out conversion....
