3 hour balancing proceedure
Q45tech
http://www.nhtsa.dot.gov/TSBScans/sb628719.pdf
The recommeded procedure to correct tire vibration problems.
Pretty much applicable to all performance tires.
See why I say tire maintenance can cost you $250 x 4 =$1,000 per year...........if you are a perfectionist.
http://ftp://ftp.nhtsa.dot.gov/tsb/
25 MB files
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Reading this now...
Grant@tirerack
That's a good read for sure :) The flat spotting refered to can happen with a lot of newer tires that have a nylon ply cap over the belts. When the tires warm up and the car is parked the weight of the car will flatten at the contact patch. Because the nylon has 'memory' it will cool and actually give you a slight vibration when you drive the car until the belts warm up again. That's probably why they say to run the car at highway speeds after each adjustment. They also specify the Hunter Road Force balancer which picks up a lot of the internal problems older balancers won't. That's the setup we use on all our packages here. I find it kind of funny that they single out aftermarket CHROME wheels. We don't handle alot of chrome wheels and we take alot of flak about it all the time. I'd love to be able to send everyone who complains about the lack of chrome wheels a copy of this :pface . The main problem is that any time you chrome a wheel it weakens the alloy a lot. They don't hold up as well as painted or polished wheels in low profile applications and the finish requires a lot more care. What a fun read! Thanks for posting this!
