Whoa, nice motor in your sig...mrzabala wrote:Very vague.... First thing you need to realize is what you want to do with your car and the ca you putting in it. Goals and what you want then realistically following through and knowning you will be changing your plan will help you get started and hopefully wouldnt bother asking this kind of ... question. Search and see what you can do to it. With 3k you can rebuilt it. But it leads to you being vague about all this.
Oh yeah? You should have bought it, I bet he would have sold it CHEAP CHEAP CHEAP.mrzabala wrote:I forgot whose ca18det this was but the guy was trying to sell it after it didnt run right when he finished the rebuild. It looked very nice on an engine stand.
Is there an echo in here?tyrannix wrote:before you start counting cash for mods and buying them, get the engine in the car.set aside up to $500 for misc junk (motor mounts?)
all your manitanence items, hoses, water and oil pumps would be great (A rebuild+balance would be better, then you can slap some forged pistons in too)
if it were me, and i was starting with an s13, an engineset from an importer +$3k
i would definatly do an 83.5mm forged piston, (~$600) balance rotating assembly, (basic rebuild kit, rings, bearings, bore+hone) (~<$800) metal head gasket ($300) (i would go tomei like i have now, i personally dont want to use a cometic)then springs ($250), cams ( <$500) cam gears ($250) and a t04E with .68 turbine (<600)then a standalone (megasquirt or SDS, either can be done and tuned for <$1000 + wideband ~$300 )700-1000 cc injectors ($200-300) adjustable nismo FPR (~$100) and a hoss fuel pump
that shopping list comes to just under $5k ... but you can do the internals (pistons, valve springs, rebuild+balance) then do stuff like cams, cam gears, standalone, hoss turbo+manifold, exhaust) later
this plan will put you on track to get a stupid fast car as you get more money
but thats just what i would do if i had to do everything all over from square 1, take it with a grain of salt and make your decisions based on research, common sense, and budget
CJ
just a bit quicker on the draw, stop resisting!float_6969 wrote:Dangit, you beat me to it...
Put the CA in a MGB with minor mods, and there ya are!adam-gtX wrote:well the goal is to run a 12 in the 1/4 also I will be rebuilding the engine with new internals block machined also I was planing on using the gt28r but I have starting thinking about the t3/t4 thanks
lol haxBwana wrote:Put the CA in a MGB with minor mods, and there ya are!
well imo the only other choice for my price range is an sr but why would I want one of those pieces when I can be only 1 of 2 ca's in towns13sr20detsilviastityper wrote:so what you are saying is.. you are going to buy a CA and will have $3000 extra?
buy a better motor in the firstplace
2JZ?float_6969 wrote:What would be your engine of choice for $4,500 dollars?
BLASPHEMY!tyrannix wrote:2JZ?
