RRRRB »
https://forums.nicoclub.com/rrrrb-u185303.html
Mon Sep 03, 2012 12:20 pm
I've tried multiple different transmission fluids in my Rb25 box, i beat this car pretty good and have always wanted the best performing fluid i could get in it. Before i rebuilt this transmission i used just run of the mill gear oil from local parts store and then tried redline the gear oil worked but it was very notchy and would grind on occasion. i never used normal gear oil again.
I switched to Redline lightweight shockproof and never looked back, until i decieded to rebuild this box due to it starting to grind and it was very noisy.
After trans rebuild i continued to use Redline until i recently switch fluids again to try Torco RTF this stuff is expensive 20 bucks a quart..
My main gripe with the redline is its cold performance and if the trans isn't fully warmed it didnt shift as smooth as i felt it should.
Mind you i shift this trans upwards of 8500RPM
The Torco RTF is hard to get not alot of places have it, but a local race team uses it in there outlaw civic that runs low 8's and love it so i gave it a try..
The trans shifts much better cold, its does seems a bit more noisy ( however that could be from the poly subframe bushing i installed as i changed fluid and bushings the same day)
This transmission shifts like butter all over the rpm range now, it has never shifted so good at high RPM i honestly cannot believe the improvement, i dont think i will find anything better than this fluid, i'm content with it and would highly recommend it to anyone looking for a better fluid.
RRRRB on Tue Jul 09, 2013 7:53 pm, edited 1 time in total.
