mexillis wrote:What is your camber at now and how often do you rotate?
I do not have the specs from the alignment but I rotate every 5k miles or so depending on usage of the car. my front tires are noticeably leaning in and the inside wear on the tire is bad. right now I have some old tires on the front but I will soon be getting some falken tires to match the rear but first I have to put the camber arms on. when my wife gets a new car and the M is mine then I will get some 20s and I want this problem solved before then.
