Yeah..Bought the
injectors from Joe of Z Speed. all 6 brand new JECS for $500 and also picked up the adapter kit that come with the connectors as well. Total bill was $682 shipped. I was planning on replacing the injectors to the newer style since they said 3 injectors were bad I figured I might as well upgrade now. The adapter kit came in this past Friday. Injectors should be delivered today...have to call Z Speed to confirm. I'd like to drop it off today and talk to the service manager to see how they dignosed it. I'm assuming with a noid light but who knows. But he did also mentioned that compression ion all cyclinders are between 182 - 185 so at least I know the motor is good. Also read somewhere that even if a injector ohms out correctly, which I believe on a Z it's 12ohms, under load it may not fire at all although it is getting a "spark" from the connector. How does one test that?
Anyway, I'm going to tell them that I want the old injectors. What do you guys think?
