capowered240 »
https://forums.nicoclub.com/capowered240-u27587.html
Thu Sep 21, 2006 4:14 pm
I posted this already in the CA forum. I just wanted a mechanics opinion on this. I have the CA18DET engine. Basically the pulsar motor.
I went to change out the injector because there was like a little puddle gas on top of #3 piston. So I change the injector out. Put everything back together. I start it back up for alittle while then shut it off. Pull #3 spark plug out and there is still gas on top of the piston.
So what I do is start it up (sounds like it is mising real bad) and pull all the coilpack connectors off one by one with the engine running. All of them except for #3 made a difference.
So I do the same thing with the fuel injector connectors. I pull all of them off one by one with the engine running. All of them except for #3 made a difference.
So I start testing all fuel injector connectors, injectors itself, coilpacks, coilpack connectors. Everything tested good and working properly. All spark plugs are getting fire.
Also did a compression test.
#1- 155#2- 160#3- 160#4- 165
I just can't figure out why when I pull the injector connector and coilpack connector on #3 it doesn't make any difference.
