boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Tue Sep 19, 2006 6:03 am
Never tested one, just threw 'em away because they are solid state and not worth screwing around with. There are a wealth of bad parts that people are unloading upon each other, so beware. If you're sure the ignitor is good or suspect that it might be good, check the ignitor's connectors at both ends. And lastly, and though it might pertain to you, on one of my Taurus SHO cars, the #6 injector was being held open by the ecu. After spending days of rinsing down my cylinder walls and running raw fuel through my exhaust, I bought another ecu and the problem was solved.
Dee
