gwoods wrote:The hemi rams came with 3.55 gears and open diffs. I did a limited slip and 3.92 gears in mine when I started getting serious about racing. Many people did 4.10 gears and I rode in and drove several trucks with 4.56 gears.
Taller the gears the faster the acceleration in EVERY gear. Taller the gears the lower the max MPH in every gear.
Yes, it will accelerate faster for each given gear, but in the long run, it still averages out. Let me provide an example:
Lets say we have 2 similar cars with the same motor, but different rear ends. The transmission gear ratios for both cars are:
1st - 16:12nd - 8:13rd - 4:14th - 2:15th - 1:1
Car A has a rear end gear with a 1:1 ratio.
Car B has a 2:1 ratio rear end.
Car A will have the same overall gearing as the transmission's gearing:
Car B will double the torque multiplication such that the overall ratio will end up being:
1st - 32:12nd - 16:13rd - 8:14th - 4:15th 2:1
Notice a pattern? The overall ratio of Car A is the exact same as Car B from second gear on. That means for a given speed, both cars will accelerate the same once Car B is out of first gear. The difference is Car B will have gained a small lead while in 1st gear, and end up at the finish line sooner. This allows Car B to grow the lead by the finish line as well as it will be at a higher speed at all times. But the instantaneous acceleration rate will remain the same from 2nd gear on.
The gear ratios I used in my example are of course, unrealistic, but even with realistic ratios, the average after 1st gear, possibly partly into second is going to be about the same. It is an effective method for increasing 1/4 mile acceleration, but I wouldn't want to take the hit in gas mileage in a daily driver. Personally, I don't do much drag racing (I prefer the twisties) so a rear end gear swap is likely not going to do much for me.
gwoods wrote:I agree with some of the gas mileage part of C-kwiks advise. If you are turning 2200 rpm at 60 mph with 3.55 gears you will turn about 2500 rpm with 3.92 gears. Higher RPM's means more gas consumption on the freeway. However on the street stop light to stop light taller gears can use less gas. Taller gears make your motors energy more efficient accelerating. It takes less gas to acclerate to 60 mph with 3.92 gears then with 3.55.
Doubtful...for the same reasons I stated above. I'd agree if the gear ratios themselves were spaced more closely together, but that isn't necessarily the case here.
Jacko3 wrote:So, why do the auto manufacturers not have the taller gears to begin with, since it improves acceleration? Apparently, according to RN79870, the 07 and 08 Sedans seem to have slightly taller gears, which probably accounts for their impressive acceleration, in addition to their improved weight, and somewhat not-so-good gas mileage, and impressive RPM range (7,000RPM +).
Manufacturers have to balance many things. Different engines have very different characteristics. Engines with peaky powerbands tend to benefit from close ratio trannies coupled to a numerically low final gear. This allows them to obtain a higher Average HP without necessitating a ton of transmisson speeds and low speed changes between each shiftpoint. Another consideration could be strength of gears and such as the size of gears are affected by their ratios.
Jacko3 wrote:So, in essence, the taller the gear, the more torque you may be generating at lower speeds, and the lower the horsepower at the top end. Seems like a game of either increasing torque and sacrificing a bit of horsepower or sacrificing torque and generating more horsepower. This is truely a difficult task ands choice for any outo manufacturer to have to deal with for RWD.
Horsepower doesnt change ever. An engine that makes X number of HP at XXXX RPM will always make that much HP at that RPM. In fact, if you calculated HP based on wheelspeed and torque at the wheels, it would be the same as the HP output at the motor at its corresponding engine RPM (ignoring drivetrain losses). FWD cars and AWD cars don't have anything different to contend with in this regard. They both still have final drive gears.
Jacko3 wrote:I can see why AWD is preferred as it probably is the best of both worlds. Of course, gas mileage will suffer under AWD.
Would you also agree that 6MTs in the north are better off with taller gears than 6 MTs in the south, since there is more snow in the north than in the south?
As I stated, AWD has nothing to do with this. Generally, manufacturers use the same differential gearing in the front and rear. If they didn't, the center diff would be under a lot of stress all the time as it would be "slipping" all the time from differing front and rear wheelspeeds.
In inclement weather, like snow, a numerically lower gear ratio would be ideal as there would be less torque at the wheels. I a number of instances, I've started a car off in 2nd gear when traction was too low to keep the wheels from spinning.
Just so everyone is clear, a taller gear is a numerically lower gear (4.09 is shorter than a 3.55 gear). This seems backwards when you think about gear ratio numbers, but the tallness and shortness of a gear refers tot eh resulting vehicle speed. That is, a taller gear will cause a vehicle to run at a higher speed for a given gear and engine RPM vs a shorter gear.
rn79870 wrote:All real quarter mile racers gear their cars so that they are a few hundred rpm short of redline in 4th gear. Not 3rd not 5th. Once they hit that magic gearing they screamed down the quarter producing the best times. Of course, they weren't concerned with rpm at freeway cruise speeds or MPG figures.
The bottom line is, if you want max performance in the quarter mile, configure your car so that you cross the end trap just shy of redline in 4th gear. This allows your engine to spend more time in the power band, or as they say, higher in the envelope.
There are all kinds of things that are done with gear ratios to try and maximize acceleration in any kind of race car. Higher HP vehicle generally need less gears as the acceleration is so fast that a typical 1st gear would be utterly useless. Note how many high HP exotics can hit 60 mph in 1st gear. Some high HP drag racers use 2 speed transmissions. In fact, one of the guys that helped bring a lot of attention to import drag racing was Adam Surawatari in his RX-7. The last set-up I remember reading about was that he ran a 2 speed powerglide. It is likely that he did gear the rear end to hit somewhere between the peak HP point and redline as he crossed the 1/4 mile mark though. Top speed race cars generally have widely spaced lower gears with closely spaced upper gears that optimize torque to the wheels as they near their projected top speed. High speed oval track gearing tends to has some similarities to this as well.
