This engine is a victim of the infamous power valve screws ingestion. It burns oil, has a cold start knock, a knock over 4k rpm, suffers from low oil pressure, and oil analysis came back not-so-stellar. However, it still runs and the vehicle is otherwise in fairly good shape. I have done quite a bit of work to the car since purchasing it in 2015 with 174k miles (most of which is documented elsewhere on this site), and so I have a comprehensive knowledge and attachment to it. Current odometer is ~204k miles.
Two days ago I began disassembly in roughly the following order:
Had the shop evacuate a/c refrigerant
Relieved fuel pressure
Removed:
hood
battery
air cleaner assembly
acceleration and cruise cables
emissions hoses; vacuum hoses and manifold
coolant
oil
upper and lower intake plenum
disconnected hoses from a/c compressor; sealed and set them aside
radiator
belts
fan and shroud
trans fluid
harness
a/c compressor
alternator
steering pump and reservoir; zip-tied to body near battery tray
fuel rail
exhaust manifold and pre-cat assembly
oxygen sensors
crank sensor at transmission
transmission fluid tubing
I used bright green masking tape to note the location of every disconnected hose, and to flag disconnected electrical connectors. Most everything was a breeze, as I have previously removed all of the above on this car except for the fuel rail and exhaust. Except for those two, removal took about six hours. The fuel rail was challenging. The exhaust was a nightmare.
When I tried to remove the exhaust manifold, several studs stayed in the heads. I figured I wouldn't be able to remove the manifolds, so I tried to remove the cats. To get at the six bolts that connect the pre-cats to the manifolds, I would have to remove the heat shields. However, most of the heat shield bolts were so rusted, and had lost so much surface area, that a socket or wrench would not turn them. I tried prying and pushing the shields aside to get to the bolts, and after much hardship was able to access three of the bolts. Two of them snapped. At this time I did not realize there were three more bolts waiting for me, on each side! I tried disconnecting the exhaust downstream, which went nowhere. I then tried cutting up one of the heat shields with tin snips, which was excruciating in that tiny space. My body gave up around 11:00 PM, after 13 hours of work.
After some much-needed rest and homemade donuts for breakfast, I took to NICO (reddit.com/r/mechanicadvice was useless, as usual). I searched for 'cat' and was lucky to find Blindaviator's post, which made me realize that I could, in fact, remove the remaining studs from the head. A 1/4" socket did the trick, although most were stubborn. I took my time, knowing that snapping one of these was not an option. Once the studs were out, the exhaust dropped away from the block. On the driver's side, the oil dipstick had to be unfastened from the block, and moved aside. On the passenger side, removal of the large mail coolant tube made stud and manifold removal easier. The downstream bolts on both cats came loose just fine, and the assemblies came out through the bay without a problem.
Tomorrow I'll remove any remaining items from the engine that may hang up, remove the transmission-to-engine bolts, and lift the engine out of the bay
