3.5 side mirrors
All things Altima Coupe.
YoungCoupe
Car: 2011 Altima Coupe 2.5s Metallic slate
I'm looking to replace the side view mirrors on my 2.5 with the 3.5 ones with the side markers. Do you think this would work? http://www.ebay.com/itm/New-Pair-Side-M ... 454wt_1185
It says its aftermarket, but it seems legit enough. And it has a lifetime warranty.
SEismyG
Car: 2008 Nissan Altima Coupe 3.5se, Fully Loaded
I don't know about that listing...check Nissan courtesy parts or an authorized Nissan parts store. Having 3.5 lights on your 2.5 WILL work without a doubt. There's a member on here that has it. Try searching him up.
YoungCoupe
Ya but I'm on a tight budget. The oem ones from courtesy parts is around $200 each, so $400 per pair. I might just take my chances lol
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Doesn't seem to bad for an aftermarket pair. Might not be the same quality as OEM, but it could be worth a shot....
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
Seems like the wiring is probably already there and existing mirrors could just be modified with a bit of dremel work and sealing.
