3.5 SE stock hid's
All things Altima Coupe.
Oilsink
Car: 08 dark slate
Has anyone replaced the stock D2R bulbs? So far ive been getting pwned by the metal cover piece behind the bulbs and i cant figure out how to get em out.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
check the interior/exterior section
phobs
You twist the metal piece (the ignitor) to unlock it. After removing the ignitor, there will be a metal clip that holds the bulb in place. You will just need to pinch it to loosen it, then you will be able to remove your bulbs.
isaac_b
Car: 2008 altima winter frost white 3.5 SE 6spd MT Premium Package
yep exactly what phobs said. if the metal braces keep getting in the was u can lift them up and kinda clip them to the part above it to hold them up so you can get the light back in. i had my wheels on when i did it so thats y i had to clip them up to the part above...
skop3.5
Car: NIssan Altima Coupe 3.5 SE Premium Package
i replaced this bulb once and it was a BI*CH to remove and install back on. after i messed with it for like 3 hours it just snapped in. I removed the whole bumper. you need to remove the whole Lamp to remove the light bulb they do this at the Dealer for 110 plus the bulb between 150 to 180
BlackMamba08
Car: 2008 Nissan Altima Coupe 3.5SE
skop3.5 wrote:i replaced this bulb once and it was a BI*CH to remove and install back on. after i messed with it for like 3 hours it just snapped in. I removed the whole bumper. you need to remove the whole Lamp to remove the light bulb they do this at the Dealer for 110 plus the bulb between 150 to 180
really? i don't remember it being that hard to remove the bulbs...
