3.5 Mirrors
All things Altima Coupe.
Joeskey
Car: 2.5 2009 Altima Coupe
Hey i tried to search around but didnt really come up with anything, i wanted to know if 3.5 mirrors would fit on my 2.5? i just want that turn signal on there.
RaiderKID
Car: 2.5 Percision Grey Altima Coupe
yes they will but you will have to have the conv. package or higher to have then on yo will need to have the seven wires not three.
Joeskey
Well im mainly worried about the fitment of them, im good at wiring and whatnot, so even if the wires arent all there, ill be able to hook them up to go with my turn signals.
toxik
Car: 09 Pearl White 370z
Joeskey wrote:Well im mainly worried about the fitment of them, im good at wiring and whatnot, so even if the wires arent all there, ill be able to hook them up to go with my turn signals.
I have a 2.5 with 3.5 mirrors. The wires are plug and play, you don't need to rewire anything, they have an adapter in the end that plugs right into an adapter from the mirrors. Removing the plastic cover that covers the mirror bolts on the interior of your door, will quickly let you see how many wires you have. Just count if you have 3 or 7 (7 meaning you're pre-wired for the 3.5 mirrors).
Replacing them took less than 10 minutes.
Joeskey
Where did u get ur mirrors from thou>?
toxik
Joeskey wrote:Where did u get ur mirrors from thou>?
some dealership, used. i would suggest finding a junk yard, otherwise theyll cost you ~$350 without paint
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
but do you have the base 2.5 or the 2.5 with convenience package?
toxik
convenience, but the whole package thing isn't 100% certain... I still tell everyone to just take off the cover and look at their wiring, even if you have base...
johnnir3volution
Car: 09 nissan altima
I have a 09 2.5s with convenience and convenience plus package. I have the 7 wires and the fuse in for the mirror defroster and mines are worthless. They dont blink and they dont defrost either. If you have an 09 its either a hit or miss, everyone with the 07-08 worked fine.
rjdmmfl1
IDK, i thought earlier someone with a 2.5 base did not have the wires when they removed their mirror... I think the convenience package thing is right, but I could be wrong
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
maybe it's similar to being prewired for fogs, how all canadian 2.5S models and higher are prewired but only certain american 2.5 models are prewired. there must be some sort of pattern to which models are prewired and which ones aren't, i can't believe that it's just hit or miss
JDRosenberg07
Car: 08 Altima Coupe 2.5 6MT
yeah that was me. I still really want the turn signals and I'm thinking of just wiring it myself for those to work. Hopefully it wouldn't be too hard to do.
