Saint wrote:My friend has a 3.5SE.It would like to know what is changed to make the 3.5 in the 350z 280HP?Is it just the ECU?Or is it cams, intake and exaust changes?He will eventualy get an Intake, headders and an exhaust.
The variance between the 3.5SE and the 350Z is only 30hp at the crank. The Altima SER is only 20hp difference. As I cant speak to the differences between the two engines, other than one is transversally mounted and the other is longitudinally mounted. The 20-30hp variances are probably made up in a freer flowing exhaust on the Z and probably a more aggressive cam setup, if I had to guess.
Quote » How would an ECU know what kind of intake or exhaust it has?[/quote]I wouldn’t really “know” what kind of exhaust or intake it has. The ECU would measure different readings and probably make adjustments to the changed airflow and exhaust flow.
Quote »A 3.5 SE and a auto 350 is there another computer that tells it:"your in a 350z"For that mater. would it know what car it is in? [/quote]There are probably big differences in the ECU between the Altima and the Z. They are two different kinds of cars and are probably incompatible with each other. I would be affraid to try mixing the two for fear of shorting the ECU out. That can typically be an expensive mistake.
Bud
