3.5 in a 2.5 engine swap? Easy?
All things Altima Coupe.
SlowCoupe08
Car: 2008 Altima Coupe 2.5
If I have a 3.5 off of an altima can I swap my 2.5 out and put it in? Can I use the same cvt as the 2.5s. What do I need to change or do to put a 3.5 in.
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
interesting, the drivers who switched their cvt transmission for a 6 speed was costly.
easily i could already think it will be expensive since you'll be swapping the engine and have a new ecu that has to go with it. also means new wires sensors and i wouldnt know if it will just be a drop in and bolt on to the current transmission.
if you have the funds then i guess its no problem
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
You'd need new engine transmission ecu mounts wiring suspension exhaust intake just to name a few.
AED
Car: 08 Altima Coupe
JMO, but unless you have some unusual attachment to the 2.5, it would be a whole lot cheaper just to trade the 2.5 for a nice 3.5
DAAN.
trading would be better in financial terms
also keep in mind you are trading in a freshly discontinued car ... for another
RicerX
Car: '20 Titan Pro4X
Buy a Z. Or a G if you want back seats.
Trust me on this - even if you go to a 3.5 coupe, from there you'll want more performance.
(this coming from a guy who bought two Altimas out of denial that a Z was what he really wanted in the first place.)
RicerX
Forgot to mention - the 2.5 and 3.5 AC barely even share anything.
They use different CVTs (including transmissino mounts), wiring harnesses, engine mounts, ECUs, and suspension parts just to name a few. The cost would be abysmally high - so much so that you might wish you bought a preowned GT-R if it's done right with OEM parts and you're paying someone for labor.
Ranga14
Car: Boosted 08 Altima Coupe 3.5
XenonSE-R wrote:Forgot to mention - the 2.5 and 3.5 AC barely even share anything.
Very well put! :yesnod
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
lulz.......
Jaxryan
Car: 2003 nissan altima
Hey everyone, so I work at a junk yard and I can get a 2003 maxima 3.5 engine and everything, harness mounts K Frame, ecm, tcm, what else do I need for motor swap?????
Jaxryan
Jaxryan
