Thanks for the quick reply Hawairish. I don't actually have a Pathfinder; I posted here because I was told Pathfinders have the same [rear] diff I have but with 3.13 gears (one source advised they were used in V6 2WD models so would have to be a rear diff). My differential is in a custom car I built; it's an MGB with a Ford 302 (5.0L) motor & an independent rear suspension that was built using a Nissan R200S differential (supposedly out of a Skyline). Pics of my car (including a couple that show the IRS & diff can be seen here:
http://www.britishv8.org/MG/RobFicalora.htm.
What I'm looking for is a differential with the same external mounting points as my existing R200S, but with taller gears -- preferably in the 3.13 range. It would be for the rear.
Googling around, I found what appear to be R200S differentials with 3.13 gears listed on ebay as Pathfinder 2wd 6 cylinder application. Example is here:
https://www.ebay.com/itm/05-06-07-08-09 ... tM&vxp=mtr.
Is the differential in that ebay listing the same case as an R200S? E.g., same mounting points?
And, if none of those came with Limited slip, anyone know if a limited slip from a C200 could be installed in them?
Note, I prefer 5-bolt axle mount flanges but I could use 6-bolt. I have adapters that convert from the Nissan flanges to 930 style CV axles which are common in custom IRS applications.
Thanks again for the help - I know this is not the norm for this board, but I figure who would know more about Nissan differentials than Nissan enthusiasts? I appreciate any info anyone can provide as I really don't want to re-make a new IRS from scratch just to get a better gear ratio for my car.
