weird that after going into "closed loop" mode, it'll run rough...
did you pull any codes at all, eventhough no CEL is on?
disconnect the o2 sensor to force it into open loop all the time & see if there's no change after operating temp is reached... sure, this is will waste gas mileage...
ps: here's the service manual for your vehicle; suggest you go thru the diagnostic section
http://www.nicoclub.com/FSM/quest/1994-1995_Quest/
download the ec.pdf file on desktop, then open w/ acrobat reader
post up the results GL
many things can go wrong... for example a few posts down w/ another person... he just guessed at his problem...
zer...-hill
Modified by ricebike at 10:30 PM 3/4/2009
